Old 09-12-2015, 03:40 PM   #11
attrapereves
Drives: 2010 Yaris 2dr 5spd
Originally Posted by CoryM View Post
It's not the slipping that hurts it, it's the sudden traction afterwards. I daily-drive (and autoX) on DOT race tires. The raw grip of these tires is far beyond what "street" tires can do. So: going around a corner hard, gas pedal to the floor to pull the car out of the corner, the inside tire spins due to weight-transfer/body-roll, then bites very hard as the weight goes back onto the inside tire. This causes a shock to the clutch similar to if you were to let the clutch out very abruptly. This usually wears/breaks the torsional springs in the clutch disc, which are there to soak up shock loads and vibration.
It's going to be about a month before I get a chance to do my clutch, but I am curious to see what it's going to look like
Cheers.
Question about that. I was teaching my wife how to drive a manual today and once or twice she accidentally revved it to 4000rpm, then launched the car screeching the tires. I'm assuming this wears the clutch significantly?
Also, sometimes when I shift into 2nd my car will jerk a little bit. Does this jerking cause clutch wear?
attrapereves is offline   Reply With Quote
