Old 09-13-2015, 12:49 PM   #1
Originally Posted by rokmeamadeus View Post
Hi guys,
Sorry to revive a dead thread, but I've run into a similar problem. Some idiot decided to rip the antenna off my 2008 hatch completely - there's no sign of the mast, and what I presume was the threaded plastic receptacle on the mount is a little warped round the edges with a red wire sticking out. I can post a picture later if that'll help.
I looked through the the forum as well as the repair manual (page AV147), but I'm having trouble figuring out what exactly came off vis-a-vis the assembly shown in the repair manual? Did he rip out a portion of the mount (that the mast would screw into, and which presumably had the red wire attached to the other side?) which is why the red wire is sticking out? I guess I can't picture how the red wire would connect to the mast if the mast screws into the mount.
Just like Hank, I'd like to keep taking apart the interior to a minimum and I don't mind getting another mast if there's a way to make the connection between that and the red wire (even if it means using JB weld at the interface).
I'd love to hear any suggestions you have.
Thanks!
There was a brass insert that the mast screwed into. This piece was bonded to the plastic to keep the base waterproof. The red wire was soldered to the bottom of the brass insert. The base also has a circuit board in it with the antenna amplifier circuit. If that was damaged the antenna will not do much.
Old 09-13-2015, 01:08 PM   #2
rokmeamadeus
Drives: 2008 Yaris (Base) LB
Thank you! That's exactly what I was looking and hoping for. The FM radio seems to work fine, although I imagine if the amplifier was damaged I'll see drop-off once I head out of the city? Even so, that isn't a problem because I rarely listen to the radio. I just wanted to figure out the quickest way to patch the thing up so it's sealed and at least semi-functional.
Thanks again!
rokmeamadeus is offline   Reply With Quote
2008 Yaris Hatchback Reddog99 Cars for Sale by private party 0 06-20-2010 11:57 AM
Is this a good deal for a 2008 hatchback? PBJ New YARIS Purchase Forum 25 11-22-2009 11:28 PM
DIY: Installing XM Radio with SureConnect antenna adapter The Marshall DIY / Maintenance / Service 0 07-11-2009 09:57 AM
Broken Antenna chip General Yaris / Vitz Discussion 6 06-13-2009 06:15 PM
FS: 2008 Yaris Hatchback Fluid Motorsports Cars for Sale by private party 0 04-24-2009 05:57 PM
