Old 09-15-2015, 06:05 PM   #1
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
DRL box under driver side dash by the steering column just unplug it
Old 09-15-2015, 07:43 PM   #2
Not on a 3rd gen. On it the DRL control is integrated into the body ECU and the relay it controls is within the 2nd under-hood fuse panel.
Old 09-15-2015, 08:21 PM   #3
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Yup, did not even see the yr in post lol
Sent from my SM-G900W8 using Tapatalk
Old 09-15-2015, 10:56 PM   #4
ucsmfu
Drives: yaris le
hello Scott,
so just remove the 2nd under-hood fuse and I should be good ?
Thanks
ucsmfu is offline   Reply With Quote
Old 09-16-2015, 06:09 AM   #5
Originally Posted by ucsmfu View Post
hello Scott,
Thanks
No. It is far too integrated for a simple solution.
Old 09-16-2015, 01:49 PM   #6
ucsmfu
Drives: yaris le
Would you recommend that I don't disable DRL, what other options do I have ?
Right now my Hids are running all day, as drl and as headlights :/
Old 09-16-2015, 06:14 PM   #7
I would have to do a bit more research on it. I think you can bypass them, but some wire cutting and possibly inserting a relay may be required.
Old 09-16-2015, 10:29 PM   #8
ucsmfu
Drives: yaris le
Alright no worries, thanks for the update Scott :)
What is it about the Yaris Ranger SVO General Yaris / Vitz Discussion 18 01-06-2015 09:45 PM
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 03:55 AM
