Old 09-17-2015, 06:57 PM   #1
attrapereves
Drives: 2010 Yaris 2dr 5spd
Took the car in for an alignment today. The car was still in alignment, but a tire rotation seemed to fix the pulling issue. I guess I should have just got the tires rotated first.
Why would tires with only 6000mi on them cause pulling like this?
attrapereves is offline   Reply With Quote
Old 09-17-2015, 07:03 PM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Did you check tire pressures? A tire's tread can cause this also if the pattern isn't in line cause it to want to walk in one direction.
Old 09-18-2015, 05:47 PM   #3
attrapereves
Yup. Pressure is good.
Old 09-18-2015, 10:36 PM   #4
CoryM
Drives: 2009 5-door, 5-speed
Darn. If only someone had suggested that..............
Tires can be bad out of the factory. They can also be damaged from impacts, driving with low pressures, sitting still for long periods, etc. Occasionally a tire pull will not get worse, but often it is indicative of a separation which will worsen (or fail). What brand of tire are they? Cheaper tires are far more likely to have leads and balance issues.
Cheers.
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 03:43 AM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
