![]() Drives: Yaris 1.0 -00 Join Date: Sep 2015
Sorry about my late response, I've tried to locate the engine serial number which I now have.
However I don't know how to decode it and I can't find anything on google. Serial number on engine is 0277368 last digit might be 9, hard to see due to rust. Does anyone know how to decode this engine serial number so I can be sure what kind of engine I have in my Yaris? Yes, I mean Check Engine Light and the engine is supposed to be a 1.0 liter 68 hp. Never had a problem with my old NGK sparkplugs which is gapped at 1.8! Installed new ones Denso K16R-U gapped them to 1.1, check engine light came on after about 75 km. When I replace spark plugs I pull the battery, then the Check Engine Light will reset. Replaced them with another set of Denso K16R-U but this time didn't gap them, same thing check engine light after about 75 km. In other words factory gapped. I have also tried tried Denso K16R-U gapped at 0.8. I can't check codes, I don't have a OBDII reader, can you recommend one? |
#2 | |
I'm willing to bet that you are throwing a misfire code which usually points to plugs or coils. If this is the case, once you read codes you will know which cylinder is misfiring. At that point, you can swap that cylinders plug for a neighbouring one and see if the code follows the plug to its relocated cylinder. If it does, bad plug. If code appears, but for original cylinder, perform the same exercise with the coil.
| Check Engine Light on at 32k kilometers? | caper26 | DIY / Maintenance / Service | 21 | 10-16-2013 12:27 PM |
| check engine light, engine turns but not start | willygoodness | DIY / Maintenance / Service | 10 | 07-23-2012 05:10 PM |
| LED'n it out (warning...big pics) | custom Lftback | Photo-Video-Media Gallery | 9 | 05-24-2010 03:41 AM |
| Spark plugs for yaris RS 2zrfe engine | candy_red | Yaris TS Talk | 3 | 11-16-2009 01:20 PM |
| Whats really going on here with maitnence light?? | la_scanner | DIY / Maintenance / Service | 4 | 03-22-2009 11:38 PM |
