Old 09-23-2015, 07:41 AM   #3
tmontague
tmontague's Avatar
Drain the oil, remove all the bolts around the pan (can't remember the size, prob 12mm)
Get a flat head screwdriver and slowly pry the oil pan away from the engine block.
If new pan came with a gasket then attach it. You also may need to all a rtv sealant as well so make sure you read instructions from the oil pan manufacturer you purchased from.
Hand loosen all bolts and then go around torquing them to spec (don't need a lot of force). Wait an hour for sealant to set I you're using rtv sealant or whatever is recommended. Add oil back and run engine to check for leaks.
Good to go. All bolts are accessible from underneath the car so just jack it up or put it on ramps and it's an easy job.
Tags
accident, oil, oil pan, repair, service
Dealer oil change boggydee DIY / Maintenance / Service 16 06-30-2010 11:21 PM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 11:51 AM
Oil Change Issue. Twistoffate0817 General Yaris / Vitz Discussion 56 05-05-2009 10:27 AM
About to do my first oil change Kaotic Lazagna DIY / Maintenance / Service 32 01-15-2007 04:00 PM
Oil change question Ryu DIY / Maintenance / Service 22 03-07-2006 11:21 PM
