Old 10-04-2015, 07:31 PM   #25
SirDigby
Drives: 2007 yaris 3 door
It is possible, if you know where the sweet spot is, to shift without needing to clutch it.
yes it's possible, but it is very hard on the edges of the gear teeth in the transaxle. it can cause issues with carrier bearings and thrust washers. I recommend only doing this...never. use your clutch. it's much cheaper than a trans.
same thing with using transmission as a engine brake, sure it will bog the engine causing friction resistance and slowing of the vehicle, but brake pads cost $60 where a worn out transaxle costs....much more
Getting Rid of the infamous Clutch "Shudder" tmontague DIY / Maintenance / Service 14 07-08-2023 01:56 PM
Clutch Maintenance fnkngrv DIY / Maintenance / Service 12 03-03-2017 10:42 AM
Unique Smell from Air Going Through AC Blower EddieCabael DIY / Maintenance / Service 30 01-19-2015 09:08 PM
need help on my 2008 yaris compress clutch susucosp DIY / Maintenance / Service 0 05-15-2014 03:48 PM
Having clutch issues ? hystria DIY / Maintenance / Service 10 08-22-2007 11:34 AM
