Old 10-04-2015, 07:51 PM   #2
SirDigby
Drives: 2007 yaris 3 door
a secondary o2 simulator sends a signal to the ecu about once every second at the correct voltage for a clean catalyst. a spacer just moves the o2 sensor away from the path. I don't know why you'd do this. if you remove catalyst an incorrect signal will be sent to the ecu tripping a cel. you should not remove your catalyst unless you are using car for racing only. you will only gain about 1-2 hp, but can incur a $10,000 epa fine if it is discovered it has been removed. FEDERAL LAW (idk about PR)
more performace/MPG with cat delete? Shinare Performance Modifications 3 06-22-2013 08:20 PM
Secondary Cat Delete? ApolloJA Performance Modifications 4 04-28-2013 11:42 AM
Cat lovers, Cat haters, this is a MUST READ *MAD DOG* Off-topic / Other Cars / Everything else Discussions 0 10-14-2012 06:20 AM
FS/ 2007-2009 YARIS 3 DOOR STOCK PARTS ROCKLAND TOYOTA Items for Sale by private party 5 06-26-2012 07:50 PM
lots of stock parts 2007 yaris h/b and some after market parts laszlo Items for Sale by private party 19 05-17-2009 04:19 PM
