Old 10-05-2015, 10:26 AM   #1
850spdr
Drives: 2013 Yaris 4d
ECM pins
I need to remove the backshells to see the wires (haven't figured that out yet, don't want to break them). Should they follow the 2007 color coding (which I have)?
850spdr is offline   Reply With Quote
Old 10-05-2015, 08:19 PM   #2
How can you say that the "pins of the ECM don't agree..." when you have never looked at them?
Old 10-09-2015, 08:20 PM   #3
850spdr
When I remove the connectors and look at the pins, they are not the same number of rows as shown in the doc, and the number of pins per row is also different. I went through and logged each pin with ignition off and on, then tried to correlate it to the connector pin-signal drawing and couldn't get a correlation.
Sorry I was gone for a few days and am late in replying.
Old 10-09-2015, 08:42 PM   #4
I just realized that you are not the original poster. The OP had a 2007. Your 2013 is a completely different ECM.
Old 12-29-2015, 01:00 PM   #5
850spdr
Resolved
I found correct schematics on Mitchell DIY site.
Need Help with 2NZ ECU pinout Aleil DIY / Maintenance / Service 3 12-28-2020 10:40 AM
I finally cracked the Odometer and SRS ECU code CTScott DIY / Maintenance / Service 22 10-27-2016 02:50 AM
standalone and stock ecu Radou Performance Modifications 0 06-16-2013 05:47 PM
The "let's brainstorm how to make a piggyback work" thread eTiMaGo Forced Induction Forum 83 08-17-2011 04:54 PM
Yaris ECU broken??!!!!!! phb10186 General Yaris / Vitz Discussion 30 05-26-2010 10:56 AM
