Wow, and I thought Phoenix, AZ was bad with regular summertime temperatures in the 45-48 degrees Celcius (113-118F) range.
The polycarbonate plastic housings of auto lights oxidize/haze under extreme UV conditions, where the UV intensity eventually destroys the OEM UV coating on them. After you get your lights re-sanded/polished or replaced, I would recommend that you get some sort of quality aftermarket UV film (such as 3M) applied to them as an extra layer of defense. That is what I plan to do with my 2015 Yaris SE before next spring rolls around here in Phoenix, AZ.
