Old 08-12-2015, 03:37 PM   #1
Deathegg
Deathegg's Avatar
Drives: 2010 Yaris hatch
rear swaybar options?
Very tempted to get a rear sway bar for my '10 3-door, but wondering if any other Toyota products had a swaybar from the factory, that I could just get cheap at the pick-a-part? Perhaps some sort of Scion?
"I like the dreams of the future better than the history of the past" - Patrick Henry
Deathegg is offline   Reply With Quote
Old 08-12-2015, 05:09 PM   #2
Rigaud
Drives: 2009 Yaris
Best sway bar is the red TRD. Your car will stop floating on the highway.
2009 Toyota Yaris (Little toy)
2002 Audi A4 Avant Quattro 3.0L (Big boy toy)
1998 Subaru Legacy GT 2.5 (winter & DD)
Rigaud is offline   Reply With Quote
Old 08-12-2015, 10:17 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
I wouldn't say the best, but it is a good one. You will have to go with something else if you want a larger swaybar than TRD.
Sent from my A0001 using Tapatalk
Old 08-12-2015, 10:55 PM   #4
Rigaud
Drives: 2009 Yaris
Good point. Would you say unless he's racing on a track, he doesn't need bigger?
What I like about the TRD one, it fits perfect. I have seen some other brands that hang lower then the TRD, that's what I didn't like.
Old 08-12-2015, 11:51 PM   #5
sickpuppy1
Drives: 2010 Yaris Sedan
They make a big difference! Mine is 17mm and works fine,but wish I would he got the 19mm. I have a sedan,so I have a bit more rear overhang.
For normal day to day driving with some "spirited" interludes... the 17 will be fine and then some.
Old 08-13-2015, 12:16 AM   #6
fj40dave
fj40dave's Avatar
Drives: '08 HB
Is the rear sway bar something a guy with a chop saw, drill press, and a mig welder could make?
I really like fabricating versus buying if possible.
Also.....any pictures of sway bars installation projects?
fj40dave is offline   Reply With Quote
Old 08-13-2015, 07:21 AM   #7
Rigaud
Drives: 2009 Yaris
No to fabricate!!!! lol
To install do a search on this forum.
Old 08-15-2015, 10:51 PM   #8
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
TRD it's cheap and it works 19mm in size
Sent from my HTC One_M8 using Tapatalk
Old 08-15-2015, 11:58 PM   #9
IllusionX
It depends on your suspension setup, racing or not. I was about to get the 21mm, but ended up with the TRD because it was way cheaper.
Anyways, with the MI springs, its impossible to drive in the winter because they are so stuff up front that make the cars understeer massively. The swaybar will correct this, and the TRD makes it very neutral, very predictable. Going with the UR 21mm will make the car oversteer more. Very useful when racing, and exit a corner at even higher speed.
Old 08-16-2015, 12:25 AM   #10
tmontague
tmontague's Avatar
I just finished. Installing the MI springs today. And had already had the TRD swaybar.
With just the sway bar the car slightly oversteered which I liked but it caught me off guard the first time.
With the MI spring and sway bar the car noow acts neutral in hard corners. I preferred a bit of oversteer but it is at least very predictable now.
There is virutally no body dway even on hard 90 degree corners. On and off ramps can be driven at least 25km/h faster with still no sway.
Both mods are well worth the cash and the MI springs are on ebay for $99 which is a great price
Old 08-16-2015, 11:13 AM   #11
Rigaud
Drives: 2009 Yaris
Yeah that I knew going 21mm is best for racing but at the time I was probably only intending to do occasional lapping. Now I'm about to get to the point of no return, meaning modding to race. Mine doesn't see winter!
Old 10-06-2015, 11:48 PM   #12
SirDigby
Drives: 2007 yaris 3 door
an anti-roll bar is a torsion bar, kinda like a spring. the steel is mathmaticly twisted when it is formed. to build one would require some kind of twisting machine and some forging hammers and some fancy dial calipers and lots of math, minimum. you can however build ladder bars and strut bars as they are not sprung steel but rigid body suspension....
Old 10-07-2015, 05:11 AM   #13
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
I think Whiteline makes one of the best ones for racing. 22mm and fully adjustable, so you can control the roll stiffness for various situations without needing to replace the wholle bar.
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog
invader166 is offline   Reply With Quote
For Sale: Ultra Racing 23mm rear swaybar $100 Mint!!! DeathBeard Items for Sale by private party 14 03-07-2011 03:44 PM
Another rear spring option! Honda Fit springs!! kngrsll Wheels, Tires and Suspension Forum sponsored by The Tire Rack 29 10-23-2009 06:02 PM
TRD Options S1L3N7 D3A7H New YARIS Purchase Forum 26 01-20-2009 02:52 PM
