Old 10-09-2015, 08:16 PM   #1
Jason@SportsCar
Originally Posted by Godfryness View Post
Hi I am new here and I don't even own a Yaris but looking everywhere it seems you guys/gals may have the answers I need.
I have a 2006 Scion xB Manual transmission. My 4 gear is now poping out and needs to be fixed. I drive a lot of freeways of 70-80mph about 80% of my driving. I am doing 25k miles a year. I love this car but don't like doing 4k rpm at 80mph. I read a forum where a guy swapped in an old Corolla transmissions with a higher final drive and said it was night and day better for all round driving and way better for freeway speeds. His rpm drooped 500 at 80mph.
I also live in ut and drive in the snow a lot. So I want to put in an LSD at the same time I fix this problem. I had been looking at c160 with LSD for a swap. But the c160 final drive is so low even with the 6th gear being taller it's really no different then my gearing now so by doing the c50 to c160 swap I only gain more gears to say in a power band and an LSD but no lower RPM for cruzing.
Is it possible to swap out the final drive in the c160 with my c50 or will that not work? If no is there a higher final drive to be had for a c160 that is not crazy expensive, like from another MT I can get at a junk yard?
Is my best bet to swap out my final drive in my c50 with the Yaris FD, fix my 4th gear poping out problem and put in an LSD? If I do that what LSD will work? I am unsure if the FD Yaris is a 6 bolt or 8 bolt like mine. If it is 6 bolt that would be a weekend part correct?
I am new to all this so any guidance is very welcome and sorry if this is all posted in the wrong place.
Chad
Popping out of 4th is likely a bad synchro, and you have to pull the trans apart to put the LSD in anyway... So put a Yaris final drive in (takes you from 4.3 to 3.7), do all new synchros, install the LSD. Also consider upgrading the clutch and installing a light flywheel - you have the car that far apart you might as well do it all.
I likely have a nearly new Yaris 3.7 if you are interested. $50 + shipping.
Old 10-13-2015, 02:18 AM   #2
Godfryness
Drives: Xb
$50 shipped, done.
Also can I put in an LSD in my xB? If so witch one?
Godfryness is offline   Reply With Quote
Old 10-13-2015, 07:52 PM   #3
Godfryness
Drives: Xb
50 and shipping. Done. Let's do it!!! I sent you my contact via pm.
test drive - comparing automatic L to manual SE cathycnm New YARIS Purchase Forum 20 11-20-2013 09:48 PM
WTB: shorter yaris final drive speed1 Willing to Buy by private party 26 10-15-2013 11:57 PM
ctrl-alt-delete question & free anti-virus question Shroomster Off-topic / Other Cars / Everything else Discussions 18 09-08-2009 03:57 AM
Question: alignment setting for a daily drive and track car? Trish Performance Modifications 4 06-15-2009 12:04 PM
I got $50 to test drive Cutie Pie #2 Off-topic / Other Cars / Everything else Discussions 6 02-23-2009 09:51 AM
