![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
Just an update: I installed a LUK clutch recently. The pedal feel is the same as OE, with maybe 10% more effort required. The OE clutch is SERIOUSLY heavy-duty. It's no wonder they last so long. The trade-off is that they are heavy. The LUK is much lighter and gives a small, but noticeable, increase in acceleration. It would probably only last half as long as an OE clutch with normal driving though.
I was thinking of trying a smaller slave cylinder bore to improve the pedal feel. Toyota has used this two-bolt style for a long time so it may be possible to find one that bolts on. The smaller bore will make the pedal effort higher, and may allow more feel. Trade-off is that it will release at a higher point in the pedal. I also had two captivated nuts for the subframe bolts spin, so had to drill holes in my floor to fix it
#2 | |
![]() Drives: 2008 Yaris Hatchback Join Date: Sep 2015
