Hm? Put a Philips head screw driver in the hole. That's the adjuster for height. There are no horizontal adjustments AFAIK. If you look down there, you will see it, it can also be adjusted with a hex wrench.
uploadfromtaptalk1445528209866.jpg Sent from my A0001 using Tapatalk |
#2 | |
#3 | |
![]() ![]() ![]() Drives: 1987 Silverado Join Date: Jan 2010
And with it i was able to adjust the lights. Thanks again |
#4 | |
That said, I noticed your reply says something totally different than his. You say its that one with the washer looking head, he says it those others. For me, the ones he said turned out to be the correct one. So is the other one for something else? |
| 3rd Gen Vitz RS (and G's) Tail Lights: Part Numbers, Ordering, and Installation | keiri | Third Gen Yaris General Discussion | 26 | 09-04-2020 12:01 AM |
| LED License plate lights for Yaris Sedan | YarisSedan | DIY / Maintenance / Service | 6 | 04-09-2013 04:05 PM |
| Instrument Panel goes out if I turn on my lights | ceceb | DIY / Maintenance / Service | 9 | 07-08-2010 05:56 PM |
| Solar powered High Bright LED lights replacing the fog lights | alan1828 | Canada | 10 | 05-14-2010 12:34 AM |
| Changing LED's In Projector Head Lights | whooppee777 | Cosmetic Modifications (Exterior/Interior) | 16 | 03-01-2009 02:07 PM |
