![]() ![]() Drives: 2010 Blazing Blue 3 Door LB Join Date: Dec 2013
I wouldnt use simple green or purple power under the hood on any car. Those products are too stong for aluminum, rubber and painted surfaces.
I like to clean my wheels, engine bay and door jams in the garage before i roll it out to the driveway for the reat of the wash process. Pop your hood and remove any leaves, sticks or debri from under the hood. I got a 4 hand held pump sprayers from HD for about 7 bucks each, I use one filled with water to spray down the engine. I prefer to use Chemical Guys All Purpose Green cleaner, its safe to use on any surface on your car. Spray down everything under the hood. Avoid spraying directly on battery terminals, around belts and pulleys, and inside the altenator. I use a few different brushes to work the dirt loose, come back and spray away the liftes dirt. Use a shop vac set to blow to remove all the left over standing water. Go find sonething else to do for 5 or 10mins while everything else drys come back and use a aerospace or back to black protectant on the valve cover, plastics and hoses. Spray wax under the hood and shock towers to keep them looking clean. Do this evey 1 or 2 months and youll have an engine bay clean enough to eat off of. If your only going to do this once a year or never before do it right after they stop laying salt on the roads, all that salt kicks up and makes it way under the hood.
15' - Crosstrek Hybrid ~ Plasma 10' - Yaris 3 Dr LB ~ The Boom Box 06' - RSX Type S ~ H.S. Dream Car 95' - Delsol VTEC ~ The Racecar 12' - Burgman 400 ~ Garage Queen 09' - Agility 125 ~ 80mpg Daily Rider 09' - Metropolitan ~ Weee 14' - Ecosmart Metro ~ Razor |
#2 | |
Thank you, I will check it out.... |
| New Spark Plugs, Engine Light Appear | grvdggr | Performance Modifications | 6 | 09-21-2015 09:34 AM |
| Stock Engine Swap | whooppee777 | DIY / Maintenance / Service | 6 | 07-14-2015 11:39 AM |
| Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 07:11 PM |
