Old 10-29-2015, 10:49 AM   #1
tmontague
tmontague's Avatar
usually would point to a bad wheel bearing...since you changed all of those and I'm assuming checked that they were good before you installed them then I'm not quite sure. Someone else will chime in I'm sure with an idea.
In regards to your coolant...ya you're going to want to deal with that asap and before you worry about a droning noise. If your coolant reservoir is constantly going empty then you have a pretty severe leak somewhere. It will leave a trail of white/pink crust (assuming you're using toyota coolant) where it's leaking so get under the car and nail down where your coolant is going.
If you have a pinkish streak running back to front under your hood just above where the water pump is then yeah you're pump is bad. Get a lifetime warranty one from parts source, not the cheapest but worth it if you change it yourself.
I wouldn't be driving the car around too much with a constantly emptying overflow reservoir
EDIT* make sure the droning isn't happening on newly paved roads only during your trip. This commonly happens until pavement is worn down a bit
Old 10-29-2015, 12:10 PM   #2
dash1979
Drives: YARIS 07
thanks for the replys everyone.
No it's not the pavement, probably a bad(new) bearing. They felt fine when I inspected them over and I guess a new water pump is in order. I'll report back once I do so further troubleshooting/inspections.
dash1979 is offline   Reply With Quote
2007 hatchback making a weird whirring sound robkay DIY / Maintenance / Service 20 03-19-2016 06:53 PM
Sound when making a left turn (a water flow sound) jimmydie DIY / Maintenance / Service 9 06-20-2013 05:35 PM
2008 Yaris sedan ‘S’ sound deadening project. Herbicidal In Car Entertainment + Electronics (audio / video / alarm) 155 09-04-2011 11:56 PM
Raising the sound stage... SAV912 In Car Entertainment + Electronics (audio / video / alarm) 11 07-30-2011 05:26 AM
New Sound System - Sound Issues click.mine In Car Entertainment + Electronics (audio / video / alarm) 11 03-20-2009 03:11 AM
