View Poll Results: Will they fit???
Yeah, probably 4 40.00%
Hell No 6 60.00%
Voters: 10. You may not vote on this poll
Old 11-04-2015, 02:23 PM   #1
justjesus
justjesus's Avatar
Drives: 2008 Liftback
haha...is the thread that old?
I'm still running them. I drive roughly 70 miles per day. I look at them almost daily, and they still look pretty much new.
Honda Civic HX wheel. Believe it's a 14x5.5 with a 45 offset. I did need a small spacer (dont know if it's 2mm, since a friend gave them to me and he doesn't know) for the front wheels to clear the caliper. It barely clears with those on there.
Kosei has a wheel (K1TS) that is 14x6 and weighs a tad over 9lbs. Offset is 38mm (look for a Honda application, ex, 1991 honda crx) and is 120/wheel. If money wasn't an issue, I'd probably run some Volk TE37s of some sort in a 14" size. I just happened to have the HX wheels sitting around from another project.
I probably wouldn't run them on lowering springs. Things get a bit tight under there with the tire at 195/75-14.
For a lift, I think I have the rear mostly figured out. Just need to use a longer shock, or use a shock extension. The front, the easiest solution is how CTScott has on his Crashy. Although I still have other ideas brewing, they're on the back burner for now while I focus on other things.
A skid plate would also be nice. Well plates. I'd like to protect the lines/wiring that run lenghwise along the "frame" rails underneath.
Old 11-05-2015, 05:03 PM   #2
thewifesyaris
thewifesyaris's Avatar
Drives: 2007 and 2008 MM Yari LBs
I guess the thread is not that old.
Thanks for the infos.
I found a cool wheel I think I will go with, not as light, but around the same price. I could probably find a dealer that can get those K1-TS's too if needed.
http://www.tirerack.com/wheels/Wheel...8&autoModClar=
These should clear without a spacer. Then I'll need to raise the car back to stock height and or look at a longer spring for the rear. Might look at getting a local shop to fab up a spacer for the front coilovers. Depends on how much clearance there is with the stock springs, I am going to do that 1st before looking at anything else.
I am curious if anyone knows of an adjustable coilover system that would allow for lowered and raised heights, so as to perhaps swap back and forth.
Anyways, this is all homework really as I just bought new tires a few months back and will likely run those till they are dead than make this change. However, it doesn't hurt to start buying things while I wait. I may get impatient and make the switch sooner too.
Two Yari on home!
thewifesyaris is offline   Reply With Quote
Old 11-05-2015, 05:38 PM   #3
justjesus
justjesus's Avatar
I like those sparcos. The design is cool.
I've been thinking of that type of coilover system for some time. For mix use between daily driving, off road, and occasional autoX. BUT that is too much to fill, as one requires stiffer spring rates (autoX). I'd still be happy with softer springs, but at least having something adjustable from being 2" taller than stock, and down to about 2" lower than stock. That's a 4" range. Likely need a totally custom set up for that.
I've been doing the homework for too damn long. But life gets in the way, so applying some of the things to the Yaris is taking forever. As it is, it took me like a year just to go back to stock height with the BFG All Terrains!
All terrain tires for cars? Captain Slow Wheels, Tires and Suspension Forum sponsored by The Tire Rack 14 11-01-2013 11:05 PM
Newly installed 15" tires feel 'weird' kristan Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 04-24-2010 06:58 PM
2007 Yaris bad tires weaver615 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 17 03-27-2010 07:21 AM
