Old 11-04-2015, 09:21 PM   #1
Kitt
Kitt's Avatar
Drives: Thndr cl metallic HB 3 drs '05
Send a message via MSN to Kitt
so, what cuts the current to the PW motor when you press the button all the way down/up is a fuse on the switch itself?
20 years... alive and kickin'!!
Kitt is offline   Reply With Quote
Old 11-04-2015, 09:36 PM   #2
There is a single fuse that feeds all of the window motors. The window switch contains the current sense circuit for stopping the window.
Old 11-04-2015, 09:39 PM   #3
Kitt
Kitt's Avatar
got it, so as you said, it should work.
Old 11-04-2015, 09:52 PM   #4
In theory. A switch from another vehicle will likely not have the correct pinout, but if you can find the wiring diagrams for both you should be able to make it work.
DIY: Colibri Power Window Install Taiyaki DIY / Maintenance / Service 15 04-28-2016 09:03 PM
Digital Gauges, Auto Climate control, Manu-matic shifter computerlove87 Cosmetic Modifications (Exterior/Interior) 21 12-02-2012 11:55 PM
