Old 11-04-2015, 09:39 PM   #1
Kitt
Kitt's Avatar
Drives: Thndr cl metallic HB 3 drs '05
Send a message via MSN to Kitt
There is a single fuse that feeds all of the window motors. The window switch contains the current sense circuit for stopping the window.
got it, so as you said, it should work.
20 years... alive and kickin'!!
Kitt is offline   Reply With Quote
Old 11-04-2015, 09:52 PM   #2
In theory. A switch from another vehicle will likely not have the correct pinout, but if you can find the wiring diagrams for both you should be able to make it work.
DIY: Colibri Power Window Install Taiyaki DIY / Maintenance / Service 15 04-28-2016 09:03 PM
Digital Gauges, Auto Climate control, Manu-matic shifter computerlove87 Cosmetic Modifications (Exterior/Interior) 21 12-02-2012 11:55 PM
