Old 11-06-2015, 01:29 PM   #4
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Thanks for the replies.
Would the serpentine belt make a similar squeal sound as most belts do when they get old? The sound I'm hearing is not that higher pitch squeal you typically hear from a bad belt. It's much more of a crunching screech. Like I said, if you've ever not realized a car was running and turned the key, it sounds more like that. A crunchy screech, more than a higher pitch squeal.
If it is the belt, could it have gotten bad/dry just from the 8 yrs of exposure? I ask because the car only has 62k miles on it.
Vitz starting issue Xuhaib DIY / Maintenance / Service 1 10-25-2013 06:13 AM
When cold starting, almost sounds like opening a fresh 2-liter Coke bottle Shinare DIY / Maintenance / Service 8 06-03-2013 04:18 PM
2009 Yaris starting issue -need help cudchew DIY / Maintenance / Service 15 12-16-2011 02:24 AM
Problems starting the engine fmicle General Yaris / Vitz Discussion 10 10-07-2009 08:48 AM
Starting Engine - Yaris Hatchback M/T gbuks General Yaris / Vitz Discussion 2 11-06-2008 12:24 PM
