Old 11-06-2015, 01:38 PM   #1
Originally Posted by ern-diz View Post
If it is the belt, could it have gotten bad/dry just from the 8 yrs of exposure? I ask because the car only has 62k miles on it.
Yes. Like any rubber product, time does deteriorate them. It may also be just fine, but needs to have the tension adjusted, but I'm betting on age.
Type of sound aside, which can be subjective when it comes to describing it, the timing of the offending sound does indicate that the serpentine is the source.
Old 11-06-2015, 01:57 PM   #2
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Gotcha. Thanks again for the info.
Is it something you would trust a good local mechanic with looking at, or should I have Toyota take a look at it on my next service appt.?
Vitz starting issue Xuhaib DIY / Maintenance / Service 1 10-25-2013 06:13 AM
When cold starting, almost sounds like opening a fresh 2-liter Coke bottle Shinare DIY / Maintenance / Service 8 06-03-2013 04:18 PM
2009 Yaris starting issue -need help cudchew DIY / Maintenance / Service 15 12-16-2011 02:24 AM
Problems starting the engine fmicle General Yaris / Vitz Discussion 10 10-07-2009 08:48 AM
Starting Engine - Yaris Hatchback M/T gbuks General Yaris / Vitz Discussion 2 11-06-2008 12:24 PM
