11-07-2015, 07:38 PM | #1 |
Drives: 2010 Yaris 2dr 5spd Join Date: Jan 2015
Transmission questions
I had a few questions about the manual transmission on my 2010 with around 75 000mi.
1) The shifter does not smoothly go into 3rd gear 75% of the time. There is a crunch feel when shifting into that gear. 2) When I take off from a stop, sometimes my car will studder and the tachometer will wiggle. Maybe I am not giving it enough gas and it's almost going to stall? 3) When shifting from 1st to 2nd, when I release the clutch after shifting into 2nd, the car lunges forward. I shift around 2700-3000rpm. 4) Sometimes my car will not shift into reverse. I have to push the clutch in and release it a few times, shift into 1st gear, then it will go into reverse. This only happens 25% of the time. Is this normal or should I be worried? |
11-08-2015, 01:48 AM | #2 |
Drives: 2005 Toyota Vitz RS Join Date: Jan 2012
4) is normal all manuals have this issue; reverse gear has an idler and no synchromesh, so if it feels like it doesn't go in. just put back to neutral, release clutch and then try again.
11-08-2015, 06:54 AM | #3 |
Drives: Vitz RS Join Date: Feb 2009
4 - for reverse I depress clutch then go into forth then reverse, others say you could do 1st then reverse.
You could change the fluid to redline MT-90. |
11-08-2015, 10:00 AM | #4 |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
How frequently does the automatic transmission fluid need to be changed? | Hamster | DIY / Maintenance / Service | 40 | 12-15-2018 09:07 PM |
My 2010 yaris is on its 4th transmission!! Help please | Uzairlexus | DIY / Maintenance / Service | 12 | 07-16-2013 10:46 PM |
Problem help | MickZEL | DIY / Maintenance / Service | 38 | 08-01-2011 02:52 PM |
Transmission Questions(fluid change... and other questions) | Lafiro | DIY / Maintenance / Service | 6 | 04-01-2009 07:52 AM |
