![]() Drives: 09 yaris s five dr stick Join Date: Oct 2015
Hey guys. Got myself an 09 Yaris recently and want to add the cruise. Ordered the OEM stalk from China and was wondering if I will need a clutch switch too. I know the guide says I do but shouldn't the car already have one? havent tried starting it without pressing the clutch in (force of habit) but the switch should prevent the car from rolling forward on the starter no?
apologize in advance if this was already covered elsewhere. -Paul |
#2 | |
![]() Drives: 2009 Yaris Join Date: Apr 2015
the two switches would be on opposite side of clutch. If clutch is fully engaged the one switch would be used. If clutch is not engaged at all, other switch would be used. If clutch is halfway between then both switch would not be used. |
thanks. since posting I went through all the pages and some associated links. Think I have a good grip on what to do. just waiting for my stalk to arrive. might skip the clutch switch for now and drive around it. sounds like I dont have to dig under the dash and engine bay if I do save it for never.
#4 | |
By my logic, If you don't have switch installed, the car will be thinking the clutch is not engaged and therefore cruise control won't turn on. If I am wrong and it works, just be careful cause if you have CC engaged and you press down on clutch, the engine will rev up quickly and could damage engine if you leave it revving long enough. |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 03:43 AM |
| DIY Cruise Control on 07-08 Yaris (step by step) | Vince87 | DIY / Maintenance / Service | 431 | 12-28-2020 01:37 AM |
| Cruise Control - Again! | CB900F2 | DIY / Maintenance / Service | 47 | 06-17-2010 06:29 PM |
| Cruise control vs MPG | YarisOwnersDad | Fuel Economy Forum | 15 | 05-29-2009 03:55 PM |
| Using Cruise control | Driver | General Yaris / Vitz Discussion | 14 | 11-09-2006 10:12 PM |
