Old 11-12-2015, 03:01 PM   #1
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Originally Posted by Kalispel View Post
On a related note, the single-blade wiper assembly on my 2015 Yaris does a far better job than any two-arm wiper assembly I have ever had on a car. It absolutely rocks.
+1 on the single wiper. Does a great job and I like the way it looks and the uniqueness factor of it.
Concerning Rain-X, I can't understand the accolades thrown at it. Everybody seems to love it but I can't see why. Several years ago I tried it out. It worked, I mean it did repel water, but there was a haze on the windshield that refracted light. During the day it was fine but driving at night was a harrowing experience. If the headlights from oncoming traffic hit at a certain angle my windshield would literally "white out". You could not see out of it and would be driving blind. Terrifying.
I figured I must have applied it wrong. (Although wipe on, buff off seems fairly straightforward.) So I removed what was there (it was a pain in the butt to get it all off), got the windshield nice and clean and tried again. Same result. Scary. I couldn't get it off my windshield fast enough.
Old 11-13-2015, 09:48 PM   #2
shepd
Drives: 2007 Yaris 5 door RS
No, you applied it properly. Rain-X is a silicone grease. It is unsurprising that it left film on the windshield.
Clean the windshield really well (use Bon Ami--if you don't clean the windshield properly the grease will prevent bonding--the shop might be able to do it for you) and have a professional glass service treat it with Aquapel. Aquapel is used on airplanes and instead of being a grease (which leaves haze and quickly wears away) it is a fluorine based compound that bonds chemically to the glass. This means it will last 2 or more months without needing re-treatment, does not affect visibility in any way, and water will bead up FAR better than Rain-X ever did. You'll find that wipers aren't necessary.
This video shows just how useless Rain-X is:
https://youtu.be/K-qhq_AigpM
Old 11-14-2015, 07:10 AM   #3
bronsin
bronsin's Avatar
How much for aquapel?
I find RainX lasts at least two months. In fact Im going out this am and put some on for winter. I will need another application before spring, if the weather permits.
BTW I find I can remove the haze just fine. Aquapel sounds great if its used on airplanes. But I bet its $$$ and if it has to be done every 2 months, that's n better than RainX.
But then I have a feeling YMMV.
variable intermittent wipers thebarber Cosmetic Modifications (Exterior/Interior) 27 10-18-2022 03:26 PM
Wipers Not Working Properly toy_toronto DIY / Maintenance / Service 8 02-05-2014 05:56 PM
Windshield Wipers misterwolfe Wash, Wax, Detailing, Exterior Repairs 6 11-13-2013 06:19 PM
PIAA Super Forza Silicone Wipers Galavoxx DIY / Maintenance / Service 3 07-20-2009 09:45 PM
Making Intermittent Rear Wipers ttufrosty Cosmetic Modifications (Exterior/Interior) 1 08-12-2007 10:57 PM
