#1 | |
Clean the windshield really well (use Bon Ami--if you don't clean the windshield properly the grease will prevent bonding--the shop might be able to do it for you) and have a professional glass service treat it with Aquapel. Aquapel is used on airplanes and instead of being a grease (which leaves haze and quickly wears away) it is a fluorine based compound that bonds chemically to the glass. This means it will last 2 or more months without needing re-treatment, does not affect visibility in any way, and water will bead up FAR better than Rain-X ever did. You'll find that wipers aren't necessary. This video shows just how useless Rain-X is: https://youtu.be/K-qhq_AigpM |
#2 | |
![]() I find RainX lasts at least two months. In fact Im going out this am and put some on for winter. I will need another application before spring, if the weather permits. BTW I find I can remove the haze just fine. Aquapel sounds great if its used on airplanes. But I bet its $$$ and if it has to be done every 2 months, that's n better than RainX. But then I have a feeling YMMV.
| variable intermittent wipers | thebarber | Cosmetic Modifications (Exterior/Interior) | 27 | 10-18-2022 03:26 PM |
| Wipers Not Working Properly | toy_toronto | DIY / Maintenance / Service | 8 | 02-05-2014 05:56 PM |
| Windshield Wipers | misterwolfe | Wash, Wax, Detailing, Exterior Repairs | 6 | 11-13-2013 06:19 PM |
| PIAA Super Forza Silicone Wipers | Galavoxx | DIY / Maintenance / Service | 3 | 07-20-2009 09:45 PM |
| Making Intermittent Rear Wipers | ttufrosty | Cosmetic Modifications (Exterior/Interior) | 1 | 08-12-2007 10:57 PM |
