Old 11-14-2015, 02:33 PM   #1
soldout
soldout's Avatar
Drives: 2010 Blazing Blue 3 Door LB
The cruise control light comes on my dash but I cant get it to activate. 2010 LB 5spd MT power package so I alreadt had the clutch switch wiring.
15' - Crosstrek Hybrid ~ Plasma
10' - Yaris 3 Dr LB ~ The Boom Box
06' - RSX Type S ~ H.S. Dream Car
95' - Delsol VTEC ~ The Racecar
12' - Burgman 400 ~ Garage Queen
09' - Agility 125 ~ 80mpg Daily Rider
09' - Metropolitan ~ Weee
14' - Ecosmart Metro ~ Razor
soldout is offline   Reply With Quote
Old 11-14-2015, 09:59 PM   #2
Did you actually install the clutch switch and is it properly adjusted, where it is fully pressed when the clutch pedal is not touched?
Old 11-15-2015, 08:03 AM   #3
soldout
soldout's Avatar
Yes, the switch wiring was taped up under the dash right above where the switch mounts. Im going to try and re adjust the switch but Im pretty sure the button is fully depressed when my foot is not on the clutch.
Old 11-15-2015, 09:49 AM   #4
I don't recall having sold you the kit, so you may want to check to make sure that the clutch switch is correct (there are two types that operate in the opposite way of each other).
Old 11-15-2015, 10:57 AM   #5
soldout
soldout's Avatar
Silly me, the first time I went to test I forgot to plug in 1 cable for the steering wheel sensor so my traction light was on, doubt CC will activate under those conditions. 2nd time I went out I plugged it in but just went around my neighborhood and wasnt going fast enough. Im my Yaris I think I have to be traveling at least 30mph to activate CC. Thanks for your help Scott.
Cruise Control Available for 06/07 Yaris TOYOTaejien General Yaris / Vitz Discussion 8 08-27-2010 12:58 PM
