#73 | |
Yes. Same OEM stalk is used for 2012 as for 2008. Other than the different release of the airbag, there is no difference for 2012 from 09-11. I have the parts required if you are interested.
#74 |
![]() Drives: Wife's Red Yaris 2007 AT 5D Join Date: Oct 2015
Dear CTScott;
I would like to install the CC on my wife's 2007 Yaris Base A/T (Hatchback). Do you still have OEM parts available? What parts do I need and how much will it cost me? I will prefer not to drill holes on the wheel cover. Thanks! |
#75 |
Yes. PM sent.
#76 |
Wiring Missing
Dear CTScott;
I have sent you a PM. I will go ahead and install the CC. But I need to purchase some wires from you. Thanks Thomascuba. |
#77 |
Missing Wires and Pictures of the Stalk I Got from Friend
Hi CTScott;
Here are the pictures of the Stalk I got. Thanks, Thomascuba |
#78 |
![]() ![]() Drives: 2010 Blazing Blue 3 Door LB Join Date: Dec 2013
The cruise control light comes on my dash but I cant get it to activate. 2010 LB 5spd MT power package so I alreadt had the clutch switch wiring.
15' - Crosstrek Hybrid ~ Plasma 10' - Yaris 3 Dr LB ~ The Boom Box 06' - RSX Type S ~ H.S. Dream Car 95' - Delsol VTEC ~ The Racecar 12' - Burgman 400 ~ Garage Queen 09' - Agility 125 ~ 80mpg Daily Rider 09' - Metropolitan ~ Weee 14' - Ecosmart Metro ~ Razor Last edited by soldout; 11-14-2015 at 02:59 PM. |
#79 |
Did you actually install the clutch switch and is it properly adjusted, where it is fully pressed when the clutch pedal is not touched?
#80 |
Yes, the switch wiring was taped up under the dash right above where the switch mounts. Im going to try and re adjust the switch but Im pretty sure the button is fully depressed when my foot is not on the clutch.
15' - Crosstrek Hybrid ~ Plasma 10' - Yaris 3 Dr LB ~ The Boom Box 06' - RSX Type S ~ H.S. Dream Car 95' - Delsol VTEC ~ The Racecar 12' - Burgman 400 ~ Garage Queen 09' - Agility 125 ~ 80mpg Daily Rider 09' - Metropolitan ~ Weee 14' - Ecosmart Metro ~ Razor |
#81 |
I don't recall having sold you the kit, so you may want to check to make sure that the clutch switch is correct (there are two types that operate in the opposite way of each other).
#82 |
Silly me, the first time I went to test I forgot to plug in 1 cable for the steering wheel sensor so my traction light was on, doubt CC will activate under those conditions. 2nd time I went out I plugged it in but just went around my neighborhood and wasnt going fast enough. Im my Yaris I think I have to be traveling at least 30mph to activate CC. Thanks for your help Scott.
15' - Crosstrek Hybrid ~ Plasma 10' - Yaris 3 Dr LB ~ The Boom Box 06' - RSX Type S ~ H.S. Dream Car 95' - Delsol VTEC ~ The Racecar 12' - Burgman 400 ~ Garage Queen 09' - Agility 125 ~ 80mpg Daily Rider 09' - Metropolitan ~ Weee 14' - Ecosmart Metro ~ Razor Last edited by soldout; 11-16-2015 at 02:16 PM. |
#83 |
![]() ![]() ![]() Join Date: Sep 2014
To install Cruise control on 2016 yaris sedan automatic transmission, i only need
846330821 Cruise control stalk 84633-02020 Cruise control wire 90080-15079 screws |
#84 | |
Correct
#85 |
Thank you
#86 |
Drives: Manual YRX 2009 Join Date: Sep 2013
Sorry if this has already been posted about but I seem to be reading a lot of conflicting information.
Can anyone help me? I Live in Australia (right hand drive) and currently own a 2009 YRX Manual Hatch. It has steering wheel audio controls. would anyone please be able to tell me what my options are for cruise control? Im a 25yr old female not so down with messing with electronic components however i want to look at my options before paying a bomb for someone to install an aftermarket kit for me. Thanks in advance! |
#87 |
![]() Drives: 2008 Toyota Yaris 4DR Join Date: May 2015
So the Toyota Yaris 2008 does not have the indicator on the instrument cluster for the engagement of Cruise Control? Is there any way to add this/upgrade the instrument cluster?
#88 |
Only via my indicator module for 06-08 Yaris.
#89 |
What about if you change the instrument panel to an 09?
#90 |
No. The ECM for the 06-08 does not support the CAN message to the cluster to turn it on.
| Cruise Control Available for 06/07 Yaris | TOYOTaejien | General Yaris / Vitz Discussion | 8 | 08-27-2010 12:58 PM |
| Cruise Control | chessclubloser | DIY / Maintenance / Service | 11 | 03-27-2010 11:59 AM |
