Old 12-04-2015, 02:58 PM   #1
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
Yes a corolla donor would work for the engine and ecm, if you want to go that route
Old 12-04-2015, 03:12 PM   #2
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
This particular paragraf in an article i read cought my attention:
Using a Toyota 1.8-litre ‘2ZR-FE’ engine force-fed by a Magnuson supercharger, the new Elise S develops 217bhp at 6800rpm – the same maximum power figure as the fizzy old ‘SC’. But it also produces much more torque than the last fast Elise: 184lb ft at 4600rpm, up from 156lb ft at 5000rpm. And this from a*car*that still weighs plenty less than a tonne, even with fluids on board.
I can only imagine what kind of performance a Yaris can have with a supercharged 2ZR-FE...
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog
invader166 is offline   Reply With Quote
Old 12-04-2015, 03:09 PM   #3
fredovvti
Drives: Yaris 07 HB
What cable you have to change?
fredovvti is offline   Reply With Quote
Old 12-04-2015, 09:48 PM   #4
ArmstrongRacing
Data doesn't lie
There are several wires that may need modification depending on your ecm/chassis. Stay tuned for a proper diy!
Old 12-05-2015, 07:14 PM   #5
kustomrtr
kustomrtr's Avatar
Drives: 2k7 Yaris
The day has come, guys. Our dreams are becoming true!
Current Mods:
aFe Cold Air Intake | Tanabe Medalion Touring (decatted) | TEIN S-Tech Lowering Springs
3000k HID fog lights | HID Custom Headlight Retrofit | Hellas Supertones | Ralco Short Shifter.
To-do list:
Lightened NST Pulleys | DC Sports Headers | TEIN Street Advance Coilovers
kustomrtr is offline   Reply With Quote
Old 12-06-2015, 07:51 AM   #6
junorico24
junorico24's Avatar
Drives: toyota yaris yrs
Is this engine found in the corolla here in Australia?
Old 12-07-2015, 03:31 PM   #7
ArmstrongRacing
Data doesn't lie
Yes it is.
Old 12-08-2015, 08:12 PM   #8
Sci
Drives: none
So maybe the 2L 3ZR-FE will fit too then? :)
Might be hard to get a manual one (at least here in Aus)
Sci is offline   Reply With Quote
Old 12-09-2015, 02:18 PM   #9
ArmstrongRacing
Data doesn't lie
Ive never seen a 3zr in person, but it looks similar.
Old 12-10-2015, 12:54 AM   #10
ArmstrongRacing
Data doesn't lie
That looks almost exactly like the 2zr...it should work also!
Old 12-11-2015, 12:37 AM   #11
7:34pm
Drives: 07 Yaris
Wouldn't the current Yaris trans mount up anyway..?
7:34pm is offline   Reply With Quote
Old 12-11-2015, 05:36 AM   #12
Sci
Drives: none
Possibly, not sure. At any rate if you were doing a swap its going to be a lot simpler with a manual 3ZR ECU running a manual box than a CVT auto ECU not expecting to see a manual box....
Old 12-11-2015, 08:49 PM   #13
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
The question is what is the difference in weights and impact on front suspension as well as handling.
Sent from my XT1575 using Tapatalk
Old 12-11-2015, 09:03 PM   #14
The weight difference is negligible. I had the privilege of driving the 2ZR swapped Yaris of this thread during my CA trip this summer and was thoroughly impressed. The acceleration of it was better than that of my supercharged Yaris and easily on par with a 8-10 psi turbo Yaris. The handling was not degraded in the least.
Old 12-11-2015, 09:12 PM   #15
fnkngrv
fnkngrv's Avatar
I was referring to the 3zr
Old 12-11-2015, 09:27 PM   #16
Ah - Totally off topic for this thread. ~40 lbs heavier than the 2ZR for ~10 HP and ~13 ft lb torque increase. Would also not likely be a drop in replacement, as the 2ZR is.
Old 12-11-2015, 09:20 PM   #17
fnkngrv
fnkngrv's Avatar
What I think would be seriously cool would be a 2zr swap that is built running 15psi of boost
Old 12-11-2015, 09:26 PM   #18
KTS
KTS's Avatar
Drives: Vitz RS
I believe the 1nz with the blitz supercharger is heavier than the 2zr.
KTS is offline   Reply With Quote
Toyota Hybrid R Shows Its Yaris Roots MadMax General Yaris / Vitz Discussion 0 10-10-2013 06:14 PM
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 03:55 AM
New Yaris race car Jason@SportsCar Tracking, Racing, Auto-X Forum 83 11-01-2012 02:32 PM
