Old 11-22-2015, 04:10 AM   #1
LTHatch
Drives: 2013 Yaris Hatchback L
Very nice! Any chance you can give us a full parts list for the swap?
LTHatch is offline   Reply With Quote
Old 11-22-2015, 11:59 AM   #2
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
Untill I know for sure if we can/cannot use the Yaris transmission, this list may need future modification. I have a spare Yaris trans already, Im currently attempting to source another 2zr for some r&d.
1) Salvaged 2zr-fe from scion Xd~$1500. This must be a complete engine with all accesories due to the updated drive belt system. Manifolds, harness.
2) Fuel injection hose from Xd. ~$60 (its longer), air conditioning compressor lines. ~$130 (compressor specific, but attatch to the lines in the car with no modifications).
3) Passenger side engine mount from Xd. ~$170
4) ECU from Scion Xd. ~$130 (depending on your car, you will need a immobilizer or non-immobilizer version....and if you have immobilizer keys will need to be registered).
5) Xd OEM airbox or intake with MAF sensor. ~$300 (updated style) and exhaust mid-pipe. ~$500-600 (larger diameter and correct cats).
6) Xd yaw rate sensor and wiring. ~$200 (A check engine light will be present due to the 2zr's traction control system)
So plan on roughly $2800 for parts, unless you buy a scion Xd as a donor vehicle.
When you power up the 2zr for the first time, you will get a check engine light. That code will point you to the wire change needed. ��
Toyota Hybrid R Shows Its Yaris Roots MadMax General Yaris / Vitz Discussion 0 10-10-2013 06:14 PM
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 03:55 AM
New Yaris race car Jason@SportsCar Tracking, Racing, Auto-X Forum 83 11-01-2012 02:32 PM
