Old 11-28-2015, 07:33 AM   #1
MedMantle
MedMantle's Avatar
Drives: Yaris '05 1.3 Hatch "R.I.P."
Could a bad ground at the fuel pump be caused because I added other things with grounds to the chassis?
I have installed an Amplifier which is grounded at the rear right seats bolting point. I also have the cheap replica Foglights which I installed into the car's fuse box for the sake of having the dash light come on when I put them on and I installed OEM window winders with a home made harness.
These things couldn't possibly be sapping power from the Pump? I'll go check my Negative Battery Terminal later **
MedMantle is offline   Reply With Quote
Old 11-28-2015, 08:28 AM   #2
bronsin
bronsin's Avatar
Hmmm my advice for a long and happy care free Yaris life has always been don't add aftermarket electrical things like alarms, remote start, etc etc. because of all the problems Ive seen and heard they can cause. I hope this isn't your problem but if possible disconnect each of things one at a time and see if the pump motor doesn't return to normal.
My first move though would be to check whatever things CT Scott says to do!
Old 11-28-2015, 10:33 AM   #3
Both of those could contribute. Depending on where you connected to for the ignition switched power for the lights, you may be directly connected to the power feed for the pump, as its power feed is one of the only easily findable ignition switched power feeds on the face of the under dash panel.
Fuel Pump Extraction - Yaris P1 johannes DIY / Maintenance / Service 0 09-06-2014 04:34 PM
2006 Yaris Fuel Pump and relay aleksii DIY / Maintenance / Service 8 04-22-2014 06:00 AM
Yaris Fuel Pump HTM Yaris General Yaris / Vitz Discussion 12 03-22-2012 03:34 AM
