Old 12-02-2015, 01:19 PM   #1
Andrinik
Drives: 1sz fe
Checked pin2 EFI relay: 0 volt.
Pin5=12 volt. No depending on key position.
Batt pin1 on ECU=12 volt.
Pin7 on ECU grounded with key inserted.
I've checked the wire from pin5 EFI to pin2ECU. It is ok.
So, no any volts on pin1 of transponder, because it after EFI relay.
Immo light flashing. Always.
Andrinik is offline   Reply With Quote
Old 12-02-2015, 09:09 PM   #2
You could try bypassing the EFI relay, by jumping 5 to 3. With MREL not having power with the key inserted, there is more likely an ECM or power to ECM issue.
I would also check on the ignition switch connector:
White/Light blue - 12 V constant power
White/Red - 12 V constant power
Black/Yellow - 12 V with Ignition in ON position
Black/Red - 12 V with Ignition in ON position
no start: engine immobilizer random issues the_teach DIY / Maintenance / Service 4 04-13-2015 07:55 AM
Spark plug gap for 04 echo donnysdayoff DIY / Maintenance / Service 2 01-16-2014 08:56 PM
viper 5901 replaced battery, crank but no start yogi In Car Entertainment + Electronics (audio / video / alarm) 1 03-25-2013 08:15 PM
Worst Cars of the 2000s (#4. Echo) MadMax General Yaris / Vitz Discussion 34 11-12-2009 10:41 AM
download for 2002 Echo Hatchback Owner's Manual hoobyjuice DIY / Maintenance / Service 8 07-03-2009 08:28 AM
