Old 12-03-2015, 11:37 AM   #1
Jason@SportsCar
Any piggyback will require feedback from its own o2 sensor and it needs to be a wideband. To be realistic you will be spending between $750-2000 when it is said and done between piggyback, harness, sensor, Dyno pulls, etc. Also because the stock ECM does a hell of a job correcting itself you will probably have issues every so often with it putting you back to 14.7 afr. I am pretty sure that Jason didn't see his gains until he installed his JUN NA Cam set which runs $1000 for the pair from JUN directly. My two cents is that you are chasing futility. The only reason why anyone has done a piggyback with this car NA is because they race with it in some form. That is the only justification for the investment. If you are going to spend upwards of $1000+ then you might as well research that 2zr swap as it is relatively straight forward, will be OEM reliable, and net around 130hp rather than the 106hp at the crank. Scott got to ride in the swapped rig AFAIK while on a trip and came away pretty impressed.
Sent from my XT1575 using Tapatalk
That is incorrect, we saw gains in Tq and HP on the stock motor with our ECU - actually the ECU was worth more than the cams. The OE tune is very conservative on fuel, ignition, and RPM. To replicate my setup would be about $3000 with the tune.
Old 12-03-2015, 12:11 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
Ah ok. I stand corrected. :-). Good to know!
1NR-FE Performance & Tuning nickstamat Performance Modifications 20 08-31-2010 05:02 AM
fog light options charleschia1986 Cosmetic Modifications (Exterior/Interior) 3 11-13-2009 04:00 PM
Anyone need ECU tuning done on American Vehicles? Nexus1155 New England 5 06-10-2009 07:15 PM
TRD Options S1L3N7 D3A7H New YARIS Purchase Forum 26 01-20-2009 01:52 PM
FS: Redline tuning Hood Lift yrsdrgn Items for Sale by private party 9 11-03-2008 08:15 AM
