Old 12-04-2015, 11:46 AM   #1
Fluxtasy
feed my pet
Fluxtasy's Avatar
Drives: Yaris Sedan '10
The Camcon has fuel settings and I understand that these settings would over ride the ECU settings unless the Camcon unit is turned off. You can check the Camcon diagram. Some wires need to be spliced while a few needs to be cut and connected to the Camcon harness.
Only if you add in or switch some new parts then you'd probably need to get it Dyno tuned again for best gains.
Fluxtasy is offline   Reply With Quote
Old 12-04-2015, 03:49 PM   #2
tmontague
tmontague's Avatar
Yes, but apparently the OE ECU can somehow override the piggyback since you are still needing to go through the ECU with the piggy back. You'd also need to install an afr sensor for the piggyback.
It sounds like it'd work great and I'd love to hear about someone giving it a go, but based on pats experiences I think that is the reason why so few run them...unless they're boosted then they have to.
If it worked flawlessly then I'd be in for sure. I think the best way to go is with a full stand alone ECU and get rid of the OE ECU. The only problem with this is the money it costs.
1NR-FE Performance & Tuning nickstamat Performance Modifications 20 08-31-2010 05:02 AM
fog light options charleschia1986 Cosmetic Modifications (Exterior/Interior) 3 11-13-2009 04:00 PM
Anyone need ECU tuning done on American Vehicles? Nexus1155 New England 5 06-10-2009 07:15 PM
TRD Options S1L3N7 D3A7H New YARIS Purchase Forum 26 01-20-2009 01:52 PM
FS: Redline tuning Hood Lift yrsdrgn Items for Sale by private party 9 11-03-2008 08:15 AM
