![]() Drives: 2014 Vitz Join Date: Nov 2015
Hi
Does anyone know where the connection for the rear wiper spray is under the hood of a 2014 Vitz/Yaris? A short hose for the rear spray is connected to the pump on one end but the other end isn't connected to anything and I can't seem to find it. Water just squirts into the engine when I turn the stalk to wash the back glass. The front one works fine. |
The hose comes off the pump, runs to the fender, then back through the lower portion of the A pillar.
Thanks. Is it supposed to be one long hose running from the pump to the rear or does it connect to a nozzle before entering the fender? The one on my pump is only 6" long.
Sounds like your hose got snipped, as there is not an inline connection there as I recall.
Thanks again. I'll try finding the other end to see if I can connect the two. Failing that I'll find a body work guy who can take apart the front to see if the other end is hiding in there somewhere.
| Tags |
| 2014 yaris, wipers |
| Wiper Motor rear | k3nty | DIY / Maintenance / Service | 15 | 08-24-2014 09:07 AM |
| Sedan REAR WIPER DIY??? | ChitownY@Ris | Cosmetic Modifications (Exterior/Interior) | 9 | 02-04-2013 09:53 AM |
| rear window wiper | yaris2010RS | DIY / Maintenance / Service | 7 | 03-25-2010 02:05 AM |
| Rear Windshield Wiper - LB | KittenRD | General Yaris / Vitz Discussion | 2 | 02-21-2010 10:19 PM |
