Old 12-08-2015, 03:49 PM   #8
Brianr4
Drives: 2008 Yaris 3dr Hatchback
think i found it
after checking all fuses, i checked the brake light switch to see if it was loose. i twisted it once and the lights came on for a second. started to tap the pedal few times and the lights would come on at times.
took the switch out and put it back in. this made them work more often, but still not every press of the pedal.
the switch plunger part is fully extending, so im guessing the switch is going out.
just sprayed with some silicone to see if that helps.
Brianr4 is offline   Reply With Quote
3rd Gen Vitz RS (and G's) Tail Lights: Part Numbers, Ordering, and Installation keiri Third Gen Yaris General Discussion 26 09-04-2020 12:01 AM
DIY yaris III fog lights installation karloslatynos Third Gen Yaris General Discussion 53 11-12-2017 03:03 PM
2007 Yaris Sedan Stop Lights Load Resistor Question crotermund DIY / Maintenance / Service 2 02-25-2015 06:30 PM
wire size for trailer lights Connoisseur_of_fine_cars DIY / Maintenance / Service 0 11-03-2011 08:09 PM
Instrument Panel goes out if I turn on my lights ceceb DIY / Maintenance / Service 9 07-08-2010 05:56 PM
