Old 12-10-2015, 07:46 PM   #1
Once you disconnect the white plastic piece for the cable, you will see a recessed area in the center of the back of the knob. The bulb is mounted into a plastic carrier there. Just use a flat head screwdriver to release it.
Old 12-10-2015, 07:50 PM   #2
buzzbuzz
Drives: 2007 Yaris
I guess I disconnect the electrical connector plus the steel control cable that moves the vents?
Do I leave the big white plastic block where it is? or do I try to get this out?
buzzbuzz is offline   Reply With Quote
Old 12-10-2015, 08:01 PM   #3
The white block does have to be removed. There are a couple of slots in the black plastic that tabs of the white part snap into. Once you release them the whole cable holder is free.
Old 12-10-2015, 08:05 PM   #4
buzzbuzz
Drives: 2007 Yaris
So you leave all the cables attached to the white block and just inch out the white plastic block and the bulb is in there?
I would assume there are plastic tabs that need to be lifted to pull out the white block?
06-10 Yaris Sedan cold air intake $40 kylevh21 Items for Sale by private party 2 04-01-2012 02:14 PM
