Old 12-14-2015, 04:18 PM   #1
Andrinik
Drives: 1sz fe
Update
Replaced immo memory from old to new ecu. Installed ecu. Immo warning light stopped flashing! It's very nice. But anyway I haven't got the ignition spark...
And no fuel injection.
Checked the wire to injectors and find bad connections. Repair this. No effect.
No sparkles, no injections- and I suggested crankshaft position sensor failure. Checked wires and figured out bad connection. Repaired.
Today I saw first time the ignition sparkles!
Unfortunately battery was out. So I will replace battery and continue...
I should to check fuel injections. What is easiest way to do this?
Andrinik is offline   Reply With Quote
Old 12-14-2015, 07:37 PM   #2
Wow - Very strange with all the wiring issues.
For checking the injectors, just listening to them click is one way of telling they are alive. Beyond that you need to power them and squirt liquid through them.
no start: engine immobilizer random issues the_teach DIY / Maintenance / Service 4 04-13-2015 07:55 AM
Spark plug gap for 04 echo donnysdayoff DIY / Maintenance / Service 2 01-16-2014 08:56 PM
viper 5901 replaced battery, crank but no start yogi In Car Entertainment + Electronics (audio / video / alarm) 1 03-25-2013 08:15 PM
Worst Cars of the 2000s (#4. Echo) MadMax General Yaris / Vitz Discussion 34 11-12-2009 10:41 AM
download for 2002 Echo Hatchback Owner's Manual hoobyjuice DIY / Maintenance / Service 8 07-03-2009 08:28 AM
