![]() ![]() ![]() ![]() Drives: 2011 Scion tC Join Date: Jul 2012
So this exists! (Aux/USB jack for aftermarket stereos)
![]() I'm about to install a Pioneer head unit and wondered where to put the USB port and the aux in jack without making it look a spastic with a hacksaw was at work there. http://www.sonicelectronix.com/item_...USB-35EXT.html Now I just need to find a spot for the microphone.
your map light is where you put your mic.
Nice Find.
This is how I mounted my mic (using a European liftback push to start trim piece and a piece of speaker grill):
That seems like a lot of work. I'm thinking about that little rubber apron between the steering column and the driver side glovebox, or one of those rectangular holes near the parking brake.
nah takes a few min. route the cable towards teh pillar (take out the glove box and gently unclip the a pillar, but dont remove the apillar), take out one visor and your map light (both you pull out) and the headliner just falls down. All this is done in literally 2 min.
If you plan on buying the adapter jack from this thread to use in a Yaris, you'll also need a USB extension cable and a male to female 3.5mm cable, because they ones up there are way too short even to reach in a straight line, much less routed through the console and hidden out of sight.
#8 | |
Pumpman
Drives: 2019 Kia Soul EV Base Join Date: Dec 2014
If not that might be one of the best places to put it since it's close to the head unit and you won't need any extensions. You can then plug in your phone and leave it in the storage area underneath the climate controls.
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog |
![]() ![]() Drives: 2007 Toyota Yaris Join Date: Nov 2015
what deck are you using?
im thinking about a mvh-x380bt |
I got this one:
http://www.yarisworld.com/forums/sho...&postcount=155 (contains parts list) Twice as much as the one you're thinking off, but I really don't care for the dash kits with storage underneath a single DIN aftermarket stereo. Gotta have that OEM look ;) |
Pumpman
If your headunit does not have a rear USB input (like mine
) you can still use the USB connection to charge your phone/GPS/other device with a voltage regulator unit like this:http://m.ebay.com/itm/271904352420?_mwBanner=1 I ordered one to use in my car. Now I just need to figure out which wires to tap into.
Well if you just wanna charge your phone/GPS/other device, you can just use the cigarette lighter socket.
#13 | |
Either way, I've since ripped everything back out and moved the entire collection into my new car.
| Does the Toyota Yaris come with a jack? | RMcG | Third Gen Yaris General Discussion | 7 | 08-20-2015 11:03 AM |
| Jack Stands, Floor Jack and Oil Filter? | 268i | DIY / Maintenance / Service | 11 | 08-03-2014 04:32 AM |
| DIY: Aux Input Jack Adapter | TinyGiant | DIY / Maintenance / Service | 11 | 11-10-2012 05:33 AM |
