If the brightness of the instrument cluster lights does not change when you adjust the dimmer rheostat, then either your headlights are not on (the headlight switch needs to be on to trigger the illumination of the AC knob lights) or the dimmer rheostat is bad or unplugged.
#2 | |
![]() Drives: 2008 Yaris Join Date: Dec 2015
Hi, Thanks for your response.
At the second I saw your comment, I went to the car and tried again. It still doesn't work and seems like the dimmer rheostat is bad or unplugged. I want to fix this, is this expensive? Or I can repair by myself? Quote:
#3 | |
For checking the rheostat you can open and remove the little storage cubby on the lower left of the dash. Once you do that you can reach in and verify that the connector is plugged in.
Yes, I can see headlight indicator light when I opened the headlight on night. Does this mean something?
It means that the signal is being fed to the dimmer to tell it to go into night mode.
That the problem is with the rheostat or its wiring.
| -Mileage Thread- -Log your mileage, year, model, color, any problems here... | Kal-El | DIY / Maintenance / Service | 322 | 07-20-2016 10:07 AM |
| Liftback Air Conditioning (Cabin) Filter info | Snappy | DIY / Maintenance / Service | 24 | 10-01-2010 06:36 PM |
| Intake Systems Decision Maker.. | Blenjar | Performance Modifications | 25 | 09-15-2007 10:07 PM |
| Finish Sedan S Intake, Paint Caliber, Air Vent Lights | jamal1984 | Performance Modifications | 9 | 03-12-2007 11:57 AM |
| Air Flow switch problem | aucorium | DIY / Maintenance / Service | 5 | 01-15-2007 04:54 PM |
