Old 12-18-2015, 01:17 PM   #1
tmontague
tmontague's Avatar
Originally Posted by xnamerxx View Post
Advance the cam from 3-5 and retard the cam above 5.
You can pretty much max the advance on this engine since there is a ton of PTV clearance.
are you talking about 3-5k rpm? or how much to advance and retard the cams?
Old 12-18-2015, 04:36 PM   #2
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Thats not a question I can answer. Due to factory tolerances, some cams may come off the line being advanced 5 degrees, some come off retarded 5 degrees, and some come off perfect. Since the camcom works in percentages, its not a easy thing to guess at, if your engine was like mine where the cam was retarded 5 degrees maxing the advance worked, if its like my old engine it would likely cost power.
I was at max advance between 3-4.5 and tapered down to 5.5 with everything above that retarded slightly. This is something that really needs to be done on a dyno.
2014 BSpec Divisional Champion
1NR-FE Performance & Tuning nickstamat Performance Modifications 20 08-31-2010 05:02 AM
fog light options charleschia1986 Cosmetic Modifications (Exterior/Interior) 3 11-13-2009 04:00 PM
Anyone need ECU tuning done on American Vehicles? Nexus1155 New England 5 06-10-2009 07:15 PM
TRD Options S1L3N7 D3A7H New YARIS Purchase Forum 26 01-20-2009 01:52 PM
FS: Redline tuning Hood Lift yrsdrgn Items for Sale by private party 9 11-03-2008 08:15 AM
