Is a piggyback not what skews the ECU? Or does a piggyback only do anything in open loop due to the ECU relearning?
#2 | |
If you're just adding fuel via modifying injector pulse widths, the ECU will correct the mixture back to stoich. If you "skew" the O2 sensor (manipulate the voltage to be either higher or lower), you're essentially tricking the ECU to think stoich is actually richer or leaner, depending on your needs. |
