Old 12-21-2015, 01:40 PM   #1
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
This still doesn't make sense to me. For one thing the Yaris auto has a lock up torque converter, so there should be no affect from that. Essentially there is a direct connection between engine, trans, and wheels when torque converter is locked up. (I may be wrong but I seem to remember reading somewhere that it locks up at 5MPH.?) No gear ratios have been changed, I don't see how engine can be turning at a lower RPM while wheels are turning at a constant MPH.
Old 12-21-2015, 03:31 PM   #2
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
That's true, but isn't the torque converter lock-up function on the Yaris performed by an electrical solenoid on the transmission, that's being controlled by the ECU?
In fact, I found an article about how on some auto transmissions, it's actually possible to perform this torque converter lock-up yourself, at almost any RPM you want, overriding the ECU settings.
http://ecomodder.com/wiki/index.php/...nverter_Lockup
But now, what I'm trying to figure out is why this happened. Why did the ECU change the torque converter lock-up speed?
"I would rather loose by a mile in a car I built myself, then win by an inch in a car that was built for me." - Moog
invader166 is offline   Reply With Quote
SIMOTA Carbon Box intake vs AFE short ram Intake walt101786 Performance Modifications 17 10-05-2012 03:01 PM
OEM Air Intake System bad Items for Sale by private party 2 04-04-2012 10:03 PM
Cold Air Intake geniusmusicman General Yaris / Vitz Discussion 4 02-17-2010 08:28 PM
simota cf cold air AlexNet0 Performance Modifications 10 04-29-2009 09:10 AM
