#1 | |
![]() Drives: Toyota yaris 2005 Join Date: Dec 2015
thanks guys, you gave me good tips
#2 | |
Degrease the wheels using dishsoap (or I rub them down with denatured alcohol). Scuff up the surface to allow the primer to bond. Either use sandpaper or coarse ScotchBrite pads. Use a good and compatible (with the paint) primer. For your Krylon paint, Krylon's primer works well.
| Wheel bearing / Outer TRE / Control Arm replacement howto | shepd | DIY / Maintenance / Service | 3 | 09-14-2015 04:20 PM |
| My 17" alloy rims and Kumho tires... will swap for your original wheels! | AutoWashCars | NY / NJ/ CT / PA | 5 | 02-08-2011 07:38 PM |
| new wheel? | Nekofelin | DIY / Maintenance / Service | 1 | 08-10-2010 02:37 PM |
| DIY : Tutorial : Paint your rims....! | hasher22 | DIY / Maintenance / Service | 17 | 11-06-2006 06:54 PM |
