Old 12-26-2015, 10:22 AM   #1
tmontague
tmontague's Avatar
Alright I took some time and sat down and read through the installation manual to get the install ready for tomorrow. since Dan's DIY is no longer available on line (if anyone has it please let me know) I have a few Q's regarding the wiring. I am installing just a keyless entry (viper 211hv)
1. For the dome light output coming from the viper harness, what wire do I tap into on the 4k connector? I looked at the Toyota wiring diagram and from my understanding it would be the pink wire. I'm still learning how to read the diagrams so it'd be great if someone with experience can confirm this for me. I know the dome light input goes to a ground so that one is easy.
2. In CTScotts guide at the very bottom for the keyless entry part it shows "transponder key bypass module connections" Do I need to tap into these just for a keyless entry (no remote start or alarm)? My understanding was I only need to connect the Viper Modules yellow wire to ignition so that I could get the locks to unlock when the ignition is off.
3. Where do I connect the viper blue wire "second unlock output" so that I have progressive unlocking? From my research my understanding is to connect it to the brown doors lock wire, is this correct?
4. Do I need to bother with any of the other wires that go to the ignition such as "unlock 87a normally closed" if all I want is for the ignition to unlock the locks when turned off? Or is just the yellow viper wire connected to 12v ignition adequate enough?
Thanks guys
Old 12-26-2015, 07:49 PM   #2
Thanks guys
1. Dome light is the pink wire of the three wires in the connector to the lower left on page 3 (labeled: power connection)
2. For keyless entry you do not need the transponder key bypass module (or the connections for it)
3. For progressive unlocking you don't need a second output - You just have to pulse the unlock wire twice with the keyless entry system (if it supports that function. If not, you would connect the second output to the same wire as the first output).
4. I would need to see the book for the unit to verify, but unlock on ignition off should not require anything more than sensing the ignition losing power.
Northeast DIY Remote Start / Keyless Entry Workshop - Sunday, October 26 CTScott General Yaris / Vitz Discussion 51 11-10-2012 01:32 PM
