Old 12-28-2015, 10:32 AM   #1
sandowian
Drives: Vitz '06 1.3L CVT
Does the CVT have a torque converter?
I've been told CVTs don't have a torque converter, but it seems to creep forward when you let go of the break like a torque converter would.
sandowian is offline   Reply With Quote
Old 12-28-2015, 06:58 PM   #2
bronsin
bronsin's Avatar
I don't see how it uses a belt.
Old 12-28-2015, 08:27 PM   #3
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
It isn't a snow machine LOL
They don't use a belt, they use a chain.
Old 12-29-2015, 05:57 AM   #4
bronsin
bronsin's Avatar
Scooter. Its a scooter.
I wonder what the rationale is for using TC on a CVT? Seems like an idjit idear.
Old 12-29-2015, 08:02 AM   #5
Bluevitz-rs
you need a way to smooth out the changing ratio, absorb shock and also give it the ability to idle in gear. A clutch would make it too harsh.
Old 12-29-2015, 09:14 AM   #6
bronsin
bronsin's Avatar
Makes sense. But then, why not just stick with regular auto transmissions?
Do other cars with CVTs use TCs?
Old 12-30-2015, 10:50 AM   #7
sandowian
What are you guys talking about? What belt/chain?
Thankfully, the US and Canadian versions don't use the CVT.
I don't see how that's relevant.
Yes - The CVT does still have a torque converter.
Thanks for a direct answer.
Old 12-30-2015, 11:14 AM   #8
This is a simple explanation of it from the service manual:
The continuously variable transaxle (CVT) assembly mainly consists of the following: a pulley and belt unit as a shift mechanism, a planetary gear unit as a forward/reverse switching mechanism, a torque converter, a differential, a CVT fluid warmer to keep the CVT fluid temperature optimal, an oil pump and a valve body unit for hydraulic control.
Name:  Yaris - CVT.png
Text in Illustration
*1 Pulley and Belt Unit
*2 Planetary Gear Unit
*3 Oil Pump
*4 Torque Converter
*5 Differential
*6 Reduction Drive Gear
*7 Reduction Driven Gear
*8 Differential Drive Pinion
*9 Differential Ring Gear
*10 Differential Pinion
Pulley and Belt Unit (Shift Mechanism)
1. The pulley and belt unit consists of a primary pulley, a secondary pulley and a metal belt applied to the pulleys.
2. In the primary and secondary pulleys integrated with the piston, the pulley groove width can be changed by each chamber's hydraulic control.
3. The metal belt consists of elements and 2 multi-layered rings which hold the elements in a belt-shaped form.
Name:  Yaris - CVT2.png
Old 12-30-2015, 02:43 PM   #9
sandowian
The continuously variable transaxle (CVT) assembly mainly consists...
Thanks a lot just what I wanted! Do you have any idea where I can get the full manual for the CVT? I asked in another thread but my replies aren't showing.
Old 12-28-2015, 07:46 PM   #10
kimona
kimona's Avatar
Drives: 2014 White VITZ
Old 12-28-2015, 08:25 PM   #11
Old 12-29-2015, 09:17 AM   #12
Bluevitz-rs
Because a CVT can give you infinite gear ratios. So your always getting the best efficiency, or the most power when needed.
Not sure how others do it, but I'd imagine they're all similar.
Just remember all modern torque converters have a locking clutch to hold them so they don't slip when they don't require to.
Old 12-29-2015, 10:50 AM   #13
bronsin
bronsin's Avatar
How has the reliability of the CVTs been? I would imagine there have been problems.
Old 12-30-2015, 01:40 AM   #14
mrpj
Drives: 2014 Icon+ 1.33l Multidrive
Not heard or read of any problems with Toyota cvts yet.
Those who criticise them have quite probably never driven one. Used because they are far more efficient than a "conventional" auto. In fact the official fuel consumption figures have the CVT achieving a better mpg figure than a manual. See 1st line of post no. 9.
I'm getting a consistent 50 miles/(Imperial) gallon.
mrpj is offline   Reply With Quote
Old 12-30-2015, 03:34 AM   #15
bronsin
bronsin's Avatar
I think one thing an auto trans can do better than a CVT is handle more hp. Yes? No?
Toyota engines and transmission on average last longer and are more reliable on average than other brands in my experience. But there isn't enough public experience with CVTs to reach a conclusion as to their life. Its possible the engineers who test them know. I think I remember automobile writers saying when they came out that they wont last as long. But then again, many of these same people think a 9 speed auto trans gets better mpg than a 3 speed.
Old 12-30-2015, 10:42 AM   #16
kimona
kimona's Avatar
I drove the Honda Fit CVT... and it was an absolute dog! The Nissan Versa Note CVT was even worse. I drove the Toyota Corolla LE CVT and it was a far better driving experience than either the Honda or Nissan. But, the Corolla L with 4-speed automatic performed so much better than LE with the CVT, and that was the single most important reason I purchased the L model. Yes, the LE got a little better gas mileage, but the price differential and driving experience wasn't worth it IMHO.
Old 12-30-2015, 11:29 AM   #17
Bluevitz-rs
I guess technically it is a belt then, except metal.
I've also been told it is actually pushed and not pulled. Does the repair manual say anything as to that?
Torque converter clutch solenoid issues Battlekat DIY / Maintenance / Service 15 12-28-2018 11:03 AM
Experiencing Torque Converter Issues invader166 DIY / Maintenance / Service 11 11-17-2015 01:35 PM
High-to-low converter Kaotic Lazagna In Car Entertainment + Electronics (audio / video / alarm) 11 05-21-2007 01:18 PM
