Old 12-28-2015, 06:58 PM   #1
bronsin
bronsin's Avatar
I don't see how it uses a belt.
Old 12-28-2015, 08:27 PM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
It isn't a snow machine LOL
They don't use a belt, they use a chain.
Old 12-29-2015, 05:57 AM   #3
bronsin
bronsin's Avatar
Scooter. Its a scooter.
I wonder what the rationale is for using TC on a CVT? Seems like an idjit idear.
Old 12-29-2015, 08:02 AM   #4
Bluevitz-rs
you need a way to smooth out the changing ratio, absorb shock and also give it the ability to idle in gear. A clutch would make it too harsh.
Old 12-29-2015, 09:14 AM   #5
bronsin
bronsin's Avatar
Makes sense. But then, why not just stick with regular auto transmissions?
Do other cars with CVTs use TCs?
Old 12-30-2015, 10:50 AM   #6
sandowian
Drives: Vitz '06 1.3L CVT
What are you guys talking about? What belt/chain?
Thankfully, the US and Canadian versions don't use the CVT.
I don't see how that's relevant.
Yes - The CVT does still have a torque converter.
Thanks for a direct answer.
sandowian is offline   Reply With Quote
Old 12-30-2015, 11:14 AM   #7
This is a simple explanation of it from the service manual:
The continuously variable transaxle (CVT) assembly mainly consists of the following: a pulley and belt unit as a shift mechanism, a planetary gear unit as a forward/reverse switching mechanism, a torque converter, a differential, a CVT fluid warmer to keep the CVT fluid temperature optimal, an oil pump and a valve body unit for hydraulic control.
Name:  Yaris - CVT.png
Text in Illustration
*1 Pulley and Belt Unit
*2 Planetary Gear Unit
*3 Oil Pump
*4 Torque Converter
*5 Differential
*6 Reduction Drive Gear
*7 Reduction Driven Gear
*8 Differential Drive Pinion
*9 Differential Ring Gear
*10 Differential Pinion
Pulley and Belt Unit (Shift Mechanism)
1. The pulley and belt unit consists of a primary pulley, a secondary pulley and a metal belt applied to the pulleys.
2. In the primary and secondary pulleys integrated with the piston, the pulley groove width can be changed by each chamber's hydraulic control.
3. The metal belt consists of elements and 2 multi-layered rings which hold the elements in a belt-shaped form.
Name:  Yaris - CVT2.png
Old 12-30-2015, 02:43 PM   #8
sandowian
The continuously variable transaxle (CVT) assembly mainly consists...
Thanks a lot just what I wanted! Do you have any idea where I can get the full manual for the CVT? I asked in another thread but my replies aren't showing.
Torque converter clutch solenoid issues Battlekat DIY / Maintenance / Service 15 12-28-2018 11:03 AM
Experiencing Torque Converter Issues invader166 DIY / Maintenance / Service 11 11-17-2015 01:35 PM
High-to-low converter Kaotic Lazagna In Car Entertainment + Electronics (audio / video / alarm) 11 05-21-2007 01:18 PM
