Old 12-28-2015, 07:06 PM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Start by looking at pictures of the two throttle bodies (eBay is a good place) and see if they're even remotely similar. If they are, then there's a possibility they will be interchangeable. There is still modifications to do though, since the intake tube is too small for the 2ZR TB, and the opening on the 1KR intake manifold will also be too small. Even if you make it fit, the only benefit you will be improved throttle response. The engine won't be able to flow enough air to take advantage of the larger valve, so there won't be any top end gains.
Old 12-29-2015, 04:04 AM   #2
saboor ali
Drives: vitz
Thanks for the reply throttle response is what I am looking for?
saboor ali is offline   Reply With Quote
Throttle Body Swap Ryze268 Performance Modifications 12 04-27-2014 01:46 PM
Cleaning throttle body ToTo Performance Modifications 18 07-27-2011 05:20 PM
1ZZ-FE throttle body crxgames Items for Sale by private party 1 04-27-2009 05:19 PM
For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers m911gt Items for Sale by private party 6 04-25-2009 08:52 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
