![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
I've been watching this post from the start and have been wondering if there is a more common (AKA cheaper) LSD option for the XD? Or another trans that bolts in?
Also, good job on the swap! |
2ZR swap. DO IT! Ask how!
Generally, no. The "cheapest" option is a Phantom Grip, which still runs a few hundred dollars and requires complete disassembly of the stock differential to install. There was an OBX-made torsen style that was hit or miss for being a grenade for around US$700 iirc, but I haven't looked for them recently. You might be able to find an OEM LSD in a junkyard if the stars all align for you, but I use US$1000 as the benchmark for adding limited slip of any kind that isn't going to be a gamble down the road.
#3 | |
Cheers |
Data doesn't lie
Drives: That Scrappy 2zrVios Join Date: Oct 2014
This is exactly my plan with my personal 2zr swap. I have a spare Yaris trans I will upgrade with the Xb final drive and a LSD....given That the yaris trans works with the 2zr.
![]() ![]() Drives: 07 Yaris 3 door Join Date: Feb 2013
For what it's worth:
On toyodiy.com 2008 Toyota Yaris NCP91 with a 1NZFE 1.5 Liter engine, uses a C50 manual trans part # 30300-52360. 2008 Scion XD ZSP110 with a 2ZRFE 1.8 Liter engine, uses a C50 manual trans part # 30300-52360. Same trans, so my guess would be that a Yaris trans will bolt to the 2ZRFE engine, or at least in this case. I've got a 2007 Yaris with an auto, and if I did this swap, would go consider going manual, but the manual trans part number for my year is a 30300-52510. I bet the difference has to do with VSS sensor vs. getting speed off of ABS, as my car doesn't have ABS. Checked the auto trans part #s, they are different from a Yaris and a XD. I'm just wondering if you can run the Yaris computer with the 2ZRFE, or if you have to swap out with an XD computer? Last edited by beaker; 01-03-2016 at 07:39 PM. |
| Toyota Hybrid R Shows Its Yaris Roots | MadMax | General Yaris / Vitz Discussion | 0 | 10-10-2013 06:14 PM |
| 2012 Yaris at SEMA | Jason@SportsCar | Third Gen Yaris General Discussion | 5 | 09-23-2013 03:55 AM |
| New Yaris race car | Jason@SportsCar | Tracking, Racing, Auto-X Forum | 83 | 11-01-2012 02:32 PM |
