Old 01-02-2016, 11:45 AM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Originally Posted by CoryM View Post
I've been watching this post from the start and have been wondering if there is a more common (AKA cheaper) LSD option for the XD? Or another trans that bolts in?
Generally, no. The "cheapest" option is a Phantom Grip, which still runs a few hundred dollars and requires complete disassembly of the stock differential to install. There was an OBX-made torsen style that was hit or miss for being a grenade for around US$700 iirc, but I haven't looked for them recently. You might be able to find an OEM LSD in a junkyard if the stars all align for you, but I use US$1000 as the benchmark for adding limited slip of any kind that isn't going to be a gamble down the road.
Old 01-02-2016, 02:09 PM   #2
CoryM
Drives: 2009 5-door, 5-speed
Thanks for the reply. Yeah, that's the price range I was finding as well. I just can't justify spending that on my Yaris even though it would make a world of difference. If I could do an easy motor swap, get more power/torque and LSD I'd be all over that though. As is, I give you guys credit for the work you've been doing; trying new things is what hot-rodding is all about.
Cheers
Old 01-03-2016, 06:07 PM   #3
ArmstrongRacing
Data doesn't lie
ArmstrongRacing's Avatar
Drives: That Scrappy 2zrVios
... If I could do an easy motor swap, get more power/torque and LSD I'd be all over that though.
This is exactly my plan with my personal 2zr swap. I have a spare Yaris trans I will upgrade with the Xb final drive and a LSD....given That the yaris trans works with the 2zr.
Old 01-03-2016, 07:14 PM   #4
beaker
Drives: 07 Yaris 3 door
For what it's worth:
On toyodiy.com
2008 Toyota Yaris NCP91 with a 1NZFE 1.5 Liter engine, uses a C50 manual trans part # 30300-52360.
2008 Scion XD ZSP110 with a 2ZRFE 1.8 Liter engine, uses a C50 manual trans part # 30300-52360.
Same trans, so my guess would be that a Yaris trans will bolt to the 2ZRFE engine, or at least in this case.
I've got a 2007 Yaris with an auto, and if I did this swap, would go consider going manual, but the manual trans part number for my year is a 30300-52510. I bet the difference has to do with VSS sensor vs. getting speed off of ABS, as my car doesn't have ABS.
Checked the auto trans part #s, they are different from a Yaris and a XD.
I'm just wondering if you can run the Yaris computer with the 2ZRFE, or if you have to swap out with an XD computer?
beaker is offline   Reply With Quote
Toyota Hybrid R Shows Its Yaris Roots MadMax General Yaris / Vitz Discussion 0 10-10-2013 06:14 PM
2012 Yaris at SEMA Jason@SportsCar Third Gen Yaris General Discussion 5 09-23-2013 03:55 AM
New Yaris race car Jason@SportsCar Tracking, Racing, Auto-X Forum 83 11-01-2012 02:32 PM
