Old 01-02-2016, 11:21 PM   #1
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Cutoff at low RPM during gentle acceleration - Yaris Verso 1.3 VVTi
Are there any codes?
Can you still drive the car or does this only happen under light throttle application?
Sent from my iPod Touch
Old 01-03-2016, 04:24 AM   #2
jackmilas
Drives: Yaris Verso 1.3 2000 automatic
There are no codes when I check it with iPhone app OBD Fusion.
I can still drive the car. It happens only at light throttle at around 1200RPM and under a load. I can't reproduce it on neutral. In normal use it just gives me one or two "jumps" during light acceleration from complete stop. 1-2 out of 5 times it won't happen at all.
My guess is that ECU cuts the fuel off because some specific sensor values are met. Things that didn't help:
- disconnecting MAF sensor
- disconnecting both O2 sensors
- 98 octane fuel instead of 95
- injector cleaner fluid
The car has 140k kms, 15 years old.
jackmilas is offline   Reply With Quote
